I just install dual autotune and it is not working.On my pc you can see the idle and afr1 and 2 but the autotune light dont want to go on.
i configure the autotune with 2 sensors.
i did a target afr but when i send the map it says....
''this map has incompatible fuel tables for the device. this map uses multiple O2 sensors and requires fuel tables to be cylinder advanced.
firmware is 1.0.6.4
the autotune module is blinking 3 times for 3 shots and then stay on when i start the atv.
i am limited in english so maybe i dont understand everything..........
need help! Thanks
firmware is 1.0.6.4
need help! Thanks
