Hi guys. First off, English is not my first language, so please bear with me.
I have a 2021 Can-Am Outlander Max XT 650 T. Yesterday when I powered up the power steering didn't work and the display reported there was a DPS problem. I switched the engine and ignition off and then back on again, and everything was fine. Then off and on again, and the error reappeared. The same has been the case today; sometimes DPS works, sometimes it doesn't.
I called the dealer who advised me to check the fuses first. I did that without finding a fault, but as everything works every other time or so, I didn't expect it to be a blown fuse.
The dealer also advised me to check that the connections on the battery terminals were sufficiently tight as the DPS unit needed a lot of power and that loose battery connections could possibly cause such errors. Both battery poles were properly tight so the fault is not there.
Are there other things I can check myself, or does the vehicle need to be taken to a dealer for more sophisticated troubleshooting? Thanks in advance.
