check with a j/d dealer and look up the part on a john deere model same year as your's and it might be even cheaper
I also need this part. Is anyone know where to buy?Ok, I've searched the online parts manuals, bought the online d/l service manual, and searched in forums, but no luck so far....
the rubber isolators in the motor mounts are just mushy in this thing, and need to be replaced, BUT the part number does not appear to be available anywhere. Anyone have any ideas?
Anti-Vibration Mount
707000002
number 20 on diagram2001 Can-Am Traxter XT, 7467/7468/7472/7481 Exhaust System | Fox Powersports Can-Am Partshouse
Shop online for OEM Exhaust System parts that fit your 2001 Can-Am Traxter XT, 7467/7468/7472/7481, search all our OEM Parts or call at 866-829-6884www.canampartshouse.com
Ducvet do you have picture of this part?They appear to be rubber isolators I do not see why they could not be made from a hard rubber or from urethane by a machine shop. Interesting they have o-rings so I expect the inside is oil fed for some reason. I assume they were trying to isolate all vibrations from the rider so if you do not mind it being a bit more vibrations you have some leeway. I would not solid mount it because if the vibrations are too harsh they will possibly cause cracking of chassis.
