1 - 6 of 6 Posts
My buddies king quad 700 Ithas err where the odometer reading should be. Is there a way to get into these things to pull codes or what does this mean machine runs fine otherwise machine is 05' or06'
The Enforcer
Sorry I didnt see it :(((
theres a service connector under the seat witha black cap on it ....the plug has 6 holes in it,:::///oneside has 2 wires the other has 1 and a blank .::/// you can put a paper clipin the side with the 2 wires .:(:)and flip it into dealer mode. you can buy a little tool to plug in it but a paper clip works great.
if ya put thevdi ecu in itya gotta putstockoneback in togo into the service code mode.
here are the codes.....
C00 NONE
C12 CRANK POSITION SENSOR
C13 INTAKE AIR PRESSURE SENSOR
C14 THROTTLE POSITION SENSOR
C15 ENGINE COOLANT TEMP. SENSOR
C20 RELAY (DIFF LOCK RELAY)
C21 INTAKE AIR TEMP. SENSOR
C23 TIP OVER SENSOR
C24 IGNITION SIGNAL (IGNITION COIL)
C32 INJECTOR SIGNAL
C40 IDLE SPEED VALVE
C41 FUEL PUMP CONTROL SYSTEM
Thank You very much will try this this week. after jumping the two wires is there anything I have to do to put it back into regular mode or will it do it itself when jumper is removed? Thanks Again Pan
1 - 6 of 6 Posts
