To remap the ECU, looks like this is needed...
Very interesting. I'm following and reading along as you post more of these. Thanks.Anyways here are some screenshots.
When I get more familiar with BUDS2, I will start making tutorial videos using the software.Very interesting. I'm following and reading along as you post more of these. Thanks.
That's an amazing idea. Create a YouTube channel for that and I am sure it will pick up and then you can monetize it. Not a lot of content on this online.When I get more familiar with BUDS2, I will start making tutorial videos using the software.
I wanted the dealer to do it a year ago. But dealer didn't want to start throwing parts at it when they could not figure out what was wrong with it.. I was also on a tighter budget too. Now my land is paid off, the only bills I have is phone and power. And a 16 yr old daughter. She is the most expensive.. 🤣You are making me really want buds. I thought you had changed cps when you were having the random no start issue?
Dealer 1.5 hours away.. That is worth having BudsYep. We used to have no Can-Am dealers around. In the last couple of years we now have 2 within 1.5 hours. A lot of my customers are switching to Can-Am so I really think BUDS is in my future to get.
Do I have some speed limiter in xmr 1000r that SHOULD be removed with BUDS2?I ordered a 2nd ECM for the purpose of experimenting with A/F parameters and exploring what else can be done. My main interests is speed limiters and A/F ratio.
Start a new thread for thisOther barrel question.
I have stock rims 6,5" width what are the widest tires (silverbacks are 9") I can put on this. Siverback are killing me - thay are funtastic in mud of course however... I do 25% mudding and when not mudding this tires just killing my front bearings and I have to replace it every 1000km- or maybe it is good result?
Yep. 65 mph. My Track Module removes the limit. I have hit 79.1 mph with the module plugged in. I want to change my limit to 75 mph without the module.Do I have some speed limiter in xmr 1000r that SHOULD be removed with BUDS2?
When I hook up my Track Module it did not remove the reverse limiter. Still had to hold down on over ride button. Does the 2021 1000 XMR have a different electrical set up. The 2021 track module was cheaper then the one for my 2014. I did not get a chance to see how fast forward would go. InterestingYep. 65 mph. My Track Module removes the limit. I have hit 79.1 mph with the module plugged in. I want to change my limit to 75 mph without the module.
UPS ... sorry you are right - Good Point - I will start new subject.Start a new thread for this![]()
Does not remove reverse limiter here either. Kinda like that actually. Especially on the 1000. A reverse wheelie is not a good thing!When I hook up my Track Module it did not remove the reverse limiter. Still had to hold down on over ride button. Does the 2021 1000 XMR have a different electrical set up. The 2021 track module was cheaper then the one for my 2014. I did not get a chance to see how fast forward would go. Interesting
