1 - 7 of 7 Posts
I have the snorkel your atv snorkels on my renegade and I think they look great but I wouldn't mind them a little taller. Has anyone extended the snorkels on the syatv kit before. If anyone has how did you go about doing it and pictures would be great. Thanks
just take the snorkels apart and add a piece of pipe in there to make them the height you want .. you can take couplers ( straight connectors ) with a short piece of pipe so the thickness of the snorkels stays the same.
Ya that will work but the engine intake snorkel (just a 90 out of the pod) is glued together I'm pretty sure. If I could take them apart it would be easy to extend but I don't want to break it trying to pull it apart.
before you take it apart -- go to the depot and get a couple 2 inch elbows and 45's and same thing with the 1 1/2 stuff -- so if anything breaks just put a new one together. really easy -- make sure you get the threaded connectors too .
Its nothing more that Home Depot plumbing store parts.....modify it as needed or scrap it and start over from scratch and built it right.
Discussion Starter #6
Ya this weekend I'll try it out. I want to keep as much of the syatv riser pieces as possible for the looks
1 - 7 of 7 Posts
