Haven't posted here in awhile but I finally found the issue why my check engine light keeps coming on at random moments. I have a 2008 Renegade 800 and I had no issues until I started taking it into deep water... thankfully I figured out about pulling the P-CODES with the simple little trick on the gauge cluster; however pulling the code wasn't as easy as it is supposed to be. Whenever I tried to pull the code, it would stay on the screen for a millisecond and they it would say NO ACTIVE P-CODES, so I decided to use my phone and take a video and pause it at the right moment. I came up with the code P0335, which translates to "Crank Pos SensorA Circ Error". I searched all over for anyone else having the same problem with their Can Am, however I found no results. Have any of you guys experienced this specific error code before? And also what is your opinion on fixing this?
I'll also provide a picture with the code.
