Front drive shaft won't come out.. Any tricks?
1820 Views 3 Replies 2 Participants Last post by  DaveB
Removed the 13mm bolt that holds the d/s to the through shaft.. Slipped the d/s back and can get it off the splines.. But I can't pull it out of the way. The d/s won't move enough to pull it away from the through shaft..
Is the rubber coupling keeping the d/s from moving back far enough? Or is there something im missing? I know you don't have to pull the front diff so Id prefer not too. When I pull the yoke off the splines and try to flip it up to clear the splines.. The edge of the yoke catches the part of through shaft.
1 - 4 of 4 Posts
Do I need to loosen the front diff?
Got the drive shaft out.. Now how do I remove the seal on the through shaft?
I removed the 3 bolts for aluminum cover.. Tried to pry it off but it won't budge.. Is there a snap ring or something im missing? Or do I continue to pry on it because it's just stuck in there? I'd really appreciate it if someone could throw in some advice as I'm currently working on it now
1 - 4 of 4 Posts
