1 - 5 of 5 Posts
Hello, I have Sunf rear 26x10-12 and 26x8-12 front tires are new and I noticed that the front tires are a little lower than the rear by about 2cm or 0.7inch, the pressure is the same for all tires.
I'm confused, I think the tires should be the same height ...
Man..... that's nothing to be concerned about........ really, lol, don't let that keep you up at night. That minor difference could be chalked up to any of a number of factors : rubber composition, rim width, and so on and so on.
Reactions: 25TH INFANTRY
2015 outlander 800r xmr
What he said in a perfect world they should be but in real life there will always be a difference.
not enough to hurt anything and is very common as the rims are usually anywhere from 1/2 inch to 1 1/2 inches different front to back which makes a difference with tire hight if one of the tires is not as wide as they say which again is very common. are you running stock rims? and on what machine?
1 - 5 of 5 Posts
