1 - 7 of 7 Posts
I have a Outlander 570 and the fuel tank appears to be not venting.
If the engine has been running it get a vacuum in side the tank.
When i open the fuel tank you hear it sucking in air.
Can anyone point me in the direction of where to find the breather???
I think that has been a running issue in all models randomly... dont limit your search to your specific size... seen one collapse the tank...
Yeah a Mate has a 650 and it did exactly that!
It made me look at mine a little closer!
I found the issue!
Coming of the tank is a clear hose that has a "T" in it.
One side does a loop around the filling point before disappearing behind the seat / frame.
The other joins upto a white breather filter which goes up in to the snorkel.
These check valves were gummed up and not venting properly which was causing my tank to run under a vacuum.
you will need to remove the seat. battery and battery tray to get access to the hosses.
99029
I'm not sure about others, and not saying you should follow suit, but I got rid of one or both(?) of those valves not long after I got my bike. Thats 6 years ago, never had an issue. I also got some more hose and ran that vent line up to the pod.
I was lucky in that I could access them from underneath above the right rear tire. Altho it was tight in there.
I found the issue!
How do you clean these air breather check valves I think my engine is starving for air after running it a few miles it is just like I am shutting the key off & on keeps dying on me is this the problem do you think?
Bob, I don't think that's your problem, but I'd advise going ahead and posting a new thread, with your bike information/age, symptoms, etc., in the correct sub-forum. I know there are plenty here that want to help, but give us something more to work with.
Welcome to the site!
1 - 7 of 7 Posts
