1 - 9 of 9 Posts
2020 outlander max xt 1000
Simply asking if anyone can recommend a good pistol grip grease gun that’s worth a shit. I’m tired of grease guns that leak/don’t work.
I got mine at Tractor Supply 15 years ago . I have a 12" rubber extension for the universals.
Still works terrific.
I do have a lock n lube on my crappy leaky grease gun. They are awesome!
With lock n lube attached can you still grease the u joints with it on? Lock n lube attachment looks beefer and I don’t know if it will fit
Discussion Starter #6
I’ll let you know
I guess I’ll have to go to tractor supply then. But I did dig out my leaky grease gun and hit greased everything but the u-joint while my tires were off. Spawn, to answer your question.... the lock n lube will not fit the u-joint
1 - 9 of 9 Posts
