1 - 8 of 8 Posts
buying a 2015 xt this week, was told they have a new color, like a dull silver ?? was wondering if any of you guys have mounted a gps to your machines ?? i DO NOT want a lil hand held gps, and if it at all possible i would not want it mounted on my handlebars, on my polaris 850 there was a perfect mounting position , thanks for your ideas...
gps
looks great, i have a slightly larger unit, i have a gps i took off my boat, trying to think where i could mount it, i may have to go withh a smaller unit, thanks for the help
With a Cell Phone Mount
I used a Cellet phone holder.
Cellet Products - Cellet Products - Noble Case
I've attached an image of the way I mounted it. I took the picture from an angle, so even though it looks like it blocks the instrument cluster, it does not from normal seating position.
I downloaded BackCountry Navigator for Android. It has offline maps so even without a cell connection you can still see maps. It has a lot of different map options Topo, street, ATV trail markings etc. Very flexible waypoints and many other features.
I had a magellan meridian mounted on mine. I made up a special plate that bolted onto the handlebar mounts and came out through a small slit in the handle bar cover. Viewing was excellent. I used a Ram mount and it never moved anywhere.
gps mount
thanks to all that replied, i was trying not to use a handlebar mount, i was thinking it would vibrate too much?? i only use machine gor ice fishing, on my polaris i mounted the garmin off my boat, its like 7 inches, i mounted that directly to the machine , the handlebars are different on the outlander, i dont think it will fit there ???? i wanted a larger unit, not a handheld gps, thanks everyone, great to switch over to can am, hope i like it as much as my polaris 850 ho xps......thanks again
1 - 8 of 8 Posts
