Grease Zirks
3.4K views 13 replies 11 participants last post by  bluefin1983
#1 · (Edited)
Grease Zerks
I have a 2014 Outlander 500 XT. I am putting it away for winter so I have been greasing the machine. I found 8 zerks in the front 4 right and 4 left. In the rear I found 3 right and 3 left and 1 in the u-joint. How many zerks are there on this machine? 15 is all I can find.
The rear, front fitting, jack up the rear and in neutral, you can usually get to it from the side through the wheel well.
Having the rear wheels off the ground allows you to spin he shaft to get the right spot.
I always pop off the rt rear wheel to get at that one...
Yea that one is a bugger on a good day...
I ride mud so I grease after every washing. U joints are expensive and will wear out. Suspension bushings are cheap quality and will go out of spec rapidly even with greasing...replace with "Garage Products" bushings when they fail.
#13 ·
Not to mention the driveshafts have a habit of taking out very expensive components when they let go.
