1 - 6 of 6 Posts
· Registered
So the belt is riding on the outside of the primary and the secondary will no disengage and thus it grind going into gear... I replaced thr primary spring and the slider shoes and served the one way clutch... it got worse! Any advice would be much appreciated
In reverse the belt rides true but as alone as I roll it forward the clutch tweaks it against the primary
Tire Wheel Automotive tire Alloy wheel Tread
9
· Admin
2020 Outlander XMR 1000r Max
Got the one way bearing in backwards?
Ps. Looks like quite the party in those two thumbnails on the right... :whistle:
Reactions: DaveB
· Registered
Hahaha opps good eye
But yes the one way clutch is in correctly the side with the lip fits towards I'm the side it fits in the recess in the inner primary should the one way clutch be kicking the belt outward?
· Regular Joe
2014 Maverick 1000r
Is the bike idling too high?
1 - 6 of 6 Posts
