1 - 2 of 2 Posts
Probably in the wrong spot but has any of you hardwired a GPS power cord to a Renegade. I have a GPS with RAM mount and a 12 volt hardwire kit I took off of my sportsman before I traded it in. The sportsman had 12 volt accessory wires under the headlight pod to hook up this sort of stuff. Does the Renegade?
Thanks
I have a Max and a Ram mount for my Montana 650. I used the hardwire kit and hooked it in to the accessory plug under the dash pod. I used some two to one spade adapters instead of cutting wire.
1 - 2 of 2 Posts
