I installed a CVtech primary on my 2018 Renegade 1000. The belt is now touching and he other sheave and causing the secondary to spin in park or neutral. This makes it hard to shift through P, H, L and neutral. One way bearing is working fine. Easily shifts when engine isn’t running
Will adding a shim to the stock secondary fix the issue? If so, does anyone know what shim is needed?
