1 - 4 of 4 Posts
Hi gang
I have a 2011 onlander 800 XTP.
Symptoms are: seems to idle fine. Up to 1/2 throttle seems to run on one cylinder. 1/2 to 3/4 cuts in and out. 3/4 to full throttle runs fine. Seems like it gets worse as it warms up. After driving it for a while at lees than half throttle the rear exhaust seem colder that the front one.
Checked: new plugs. Fuel injectors are spraying fine. Fuel pressure is fine. Cleaned mass air flow sensor.:th_smiliefrustrated:th_smiliefrustrated
Need help figuring out what to look at next?:th_smiliefrustrated
Thank you
have you tried your other key?
1 - 4 of 4 Posts
