1 - 4 of 4 Posts
I want to replace the rear shocks from my Outlander 800 Max LTD and remove or disable the ACS system. Can I simply remove the shocks and disconnect the compressor?
Discussion Starter · #2 ·
Anyone?
plug the lines 1/8 jic fittings - you'll probably need to order them off the internet.
may have problems from there though, some report no issues. Mine cycles the compressor about every 10-15 sec for 1-2 sec. Eventually it'll throw a fault. Restarting the machine will clear the fault.
It's mildly annoying at this point, so I'm all ears if you find a better (than having mrrpm program the ecu at $500) solution
I disabled the power connector to the compressor. I do see an error message in the display after riding for an hour or so but it does not go into limp home mode.
1 - 4 of 4 Posts
