1 - 1 of 1 Posts
I have a 2000 Traxter 500 that I bought and have been working on. It currently does not run but I am trying to solve that as I have several issues. But the one that I would like some input on is the ignition wiring. I bought a new ignition switch and hooked it up. It did not work so I pulled all the tape off the wiring harness so I can see the wires. I see that the new ignition plug has three wires and one is a green wire. This new plug plugs into a connector in the harness. The wire is then red with a stripe coming out that matches up to the green. The previous owner had this disconnected and I am not sure where it is supposed to connect to in the sea of wires in the harness. I think I found what looks like the correct spot in a factory splice. Can you look at the picture and let me know if this is where I should splice this red wire back into the harness. The wires at this spot are always hot when I put a tester on them.
1 - 1 of 1 Posts
