1 - 16 of 16 Posts
hello all, my 2016 Outlander 570 left me stranded on my elk hunt!!! ran great, then started smelling gas, and had no power in low speed, Barely would move, backfire from exhaust and engine. Will idle fine, but when you engage the throttle it will die or backfire. Every once in a while, it will get up to speed and then run fine at 25mph or above, when you back out of throttle it backfires and wont get back up to speed. it is also dumping fuel....the ride that usually takes 1/4 tank dropped almost 3/4 tank.. reaks of gas..... thx in advance for any diagnostics, hope to get back to hunt!!!
Welcome to the site
When's the last time you changed the plugs?
It could be an injector(s) issue, but without spark, you'll also get all of those symptoms. Plus, they're super cheap and easy to change.
Next up after plugs would be to confirm your fuel system pressure, make sure the pump isn't failing. It's much more likely one of those two are the issue, than your injector(s), imo
2017 Can-Am Outlander 570 Pro
change the spark plugs for irridium ones , they last longer and runs better
In your experience could that cause the issue? I am NOT familiar with ATVs obviously, but pretty capable with car repair and have never seen or heard of spark plugs causing the significant issues and fuel dump like I am having. BUT you folks have been kind to offer advice that i am grateful for. Will try the plugs. Any good videos on removing all the plastic on the Outlander to expose the motor…… afraid of snapping off the clips. Thx again for your help!! Pete
These should help you out. Good luck.
Reactions: BombardierBomb
Thank you sir!!!! Well spark plugs didn’t do it….. so against my better judgment I am buying a $300 fuel pump hoping that works…… need to get back on the road..
Check out Quantum. ~$100 and lifetime warranty. Don't overspend on OE
Well, I hear ya, I am in a bind and they have one!! If it’s not the pump, I am out the money!! No returns…..
Don't just go throwing money/parts at it. Borrow an EFI system pressure test kit from your local auto parts store. You should ~51psi fuel pressure out of these systems
Well, that would have been the best idea!! Unfortunately I am a moron and don’t always do the best thing!! I really appreciate your quick and helpful responses!!! I may be asking for more of them! 😀😀
1 - 16 of 16 Posts
