installing a winch on a 2018 Outlander 570L DPS
11K views 24 replies 13 participants last post by  Jorge570
I am installing a winch on a 2018 OUtland L570 DPS. I cannot seem to find a place to mount the relay. Does anyone have a suggestion?
there is probably a way to do it, but this is exactly why I bought an XT....
exactly what Jorge says. There is a bracket, on the right hand side, just behind the panel. that's where mine is. I had mine put on after I had purchased the 570 Max.
#16 ·
It will easily hold 50 feet of synthetic. I went up a size in synthetic to 1/4" and put in 40 feet and I likely could have stayed with 50 feet without any problem whatsoever.
#17 ·
Javelina 1, I will try to find the bracket again.
Jorge570 and WIoutty, thanks for responding, but the problem i am having is mounting the relay.
I am starting to think I should have just paid the dealer to put it on.
#19 ·
What is the issue that you have with mounting the relay?
why not just drill a hole in the frame and mount it with a screw wherever it fits the best with the wire length etc?
or just use heavy duty tie wraps and tie it to anything solid with a few strong tie wraps or a stainless collar?
#18 ·
I may have misunderstood you. I mounted my four post terminal where I stated before behind plastics on right side front. My relay I installed on the outside of rear storage box. I would have installed inside rear storage but wire wasn't long enough
