1 - 7 of 7 Posts
I’m seeing you can’t get the cam am iso flex grease from cam am anymore need to get some. Any ideas guys??
Are you refilling the actual bearings or just lighty smearing the friction washer and snout ?
If you're removing the seals and repacking the bearings, I have always used whatever was in my grease gun .
For the snout , washer and caps I use Iso but in a pinch I would choose a (synthetic ) grease with a very high drop point.
I ordered a small 50gr tube of if 12 years ago from this place, fyi you want the Topas NB52. amazon has it to.
My service interval for the clutch is coming due and I can't help but wonder if a dry-film lube would work on the inner sleeve , friction washer and snout .
Or should I say how long would it work ....
98651
TWO - 2013 XTP 800 -
Aircraft landing gear grease. $20 Canuck bucks a tube. I grease the quads with it as well. Sticks like cat shyte to a blanket.
1 - 7 of 7 Posts
