Hi,
I got a 2006 Buck from a family member, ridiculously low miles. Maybe 50 miles or so, webbing still on tires. I have been told this is the same as a Traxtor 500 but I am not up on that history. I know the Buck is very different from the Trail Buck of the same year.
I just got it, hadn't been used in 3 years. Runs decent, will go through the carb when I have time later. The urgent issue is that the speedo/instrument cluster/indicator cluster and taillights are not working. I have found a parts diagram and suspect a relay in the ignition switch circuit. Thought someone might be able to chime-in on this possible solution and also tell me where that relay might be?
Thanks!
Thanks!
