I just bought a 2005 can am outlander 400 for $2900 cad. It has unknown km because the speedometer and odometer was broken but it looked solid but it has a good amount of rust and the body was a little rough. I looked for cracked frame and made sure the choke worked and it works good. The tires are worn and needs to be replaced because they are worn out, the exhaust is rusted out and needs to be replaced. Most of the rust was spray painted out because he was covering up the rust. The problem that I saw is that it was a Canadian government machine so it was most likely maintained well but was probably run hard.
I just have a few questions:
What are some of the things I should check?
What exhaust should I replace it with? Aftermarket or stock?
It had 120PSI compression is that good And what was it factory?
What are some good trail/mud tires?
I’m used to a 1986 Honda trx350 so this is quite a step up for me.
