I added the 20 inch Cree light bar a while back. The wiring kit they sent was junk, it started flickering after 1 ride. So I cut the high beam and ground wire to the headlights (they are 16 gauge) and spliced the 12 gauge light bar wires into them. So I have had it running fine for 3 or 4 months with the 16 & 12 gauge running into a 16 gauge. Now when I turn the wheel it fades out, my guess is because the electric power steering taking battery power. So would changing the wires to run the 16 & 12 into a 18 gauge wire help this? How do you guys have your lightbars running with your headlight switch?
