Got any pics?I used a metal gutter guard inserted and clamped with a hose clamp. Over that I have a filter type bag. The metal screen stops it from being sucked into the intake (which happened at full throttle when I first put the socks on) .
YES. I remember playing with Frogskin and Florites years ago with my big bore carbed mud machine....the screens required 10 jet sizes smaller to run right: WAY LESS AIR FLOW. I take those screens and hurl them. The airbox has an air filter in it and the CVT is a belt and clutches....unless you throw rocks in there, I've never had an issue running open snorkels.Do your research though; some restrict airflow a whole lot.
Too late. It hammered a bunch of holes in my clutch cover and gouged the hell out of the clutches hahaMake sure you remove the metal piece behind the shield I had a few bikes roll and dislodge the metal support and the sucked it through the cvt and cause some problems.
Bugger the one it happened to with us punched a hole in the cover and caused the belt to leak we had only just had the cover of and changed the belt so of course the customer blamed us until we found this little item hiding in behind the clutch cover.Too late. It hammered a bunch of holes in my clutch cover and gouged the hell out of the clutches hahaMake sure you remove the metal piece behind the shield I had a few bikes roll and dislodge the metal support and the sucked it through the cvt and cause some problems.
