1 - 1 of 1 Posts
Hey guys, need some help diagnosing an electrical issue on my quad. When I'm running my hand warmers and lights at idle, the low battery voltage light appears! At first I didn't think it was an issue because I know the charging system on these quads are weak, but as soon as I try using my winch under load, it throws the quad into limp mode home!
I have a 2010 Renegade 800r, no dps. I've installed a warn 2500 winch and hand warmers. I replaced the battery with a Deka 20l. After running some tests at the battery, my quad is putting out 13.5-14.3 dc volts at idle. It does increase with additional rpm. However, when I turn my heated grips on and the lights on the dc volts fluctuate between 12.3-12.6. My buddy has a 500 renegade with warmers and a winch and his constantly puts out 14 dc volts at the battery regardless of the lights/warmers on. His seems to hold steady? We swapped the rectifiers and still the same readings on my quad...any ideas?? I even disconnected the winch and warmers to ensure they weren't drawing and I still have the fluctuation in dc volts at idle - 13.4-14.3.
I also checked resistance in the stator and all terminals are around .2ohms. My stator is also putting out 16.8-18 ac volts at idle and 40+ ac volts at 4000rpm. Manual states that it should be between 10-25 ac volts at 4000rpm, but my buddies quad tests the same.
1 - 1 of 1 Posts
