http://f.mail.brp.com/i/38/208878865...sFoxShocks.pdf
This information will assist you with fully utilizing the high-quality shocks on your Maverick X ds. Here is an overview 1 of available adjustments.
This example list of shock settings is representative of a 2 setup used by a driver in dunes facing numerous whoops at a fast speed and is used only as reference for what can be done.
1. Spring Preload:
The spring preload adjustment has an impact on the stiffness of your shocks and the ground clearance of your vehicle. To increase the spring force and provide a firmer riding experience, turn the adjuster ring downward (shorten the spring). This also increases the ground clearance and center of gravity of the vehicle. To decrease the spring force and provide a more comfortable riding experience, turn the adjuster ring upward (lengthen the spring). This action decreases the vehicle’s ground clearance and center of gravity.
To increase preload (stiffer), turn the adjuster ring downwards. To decrease preload (soften), turn the adjuster ring upwards.
Note: If you added extra weight or height to the vehicle (ex. bigger tires, roof, doors, etc.) it’s important to re-adjust the ground clearance to 13-in (rear). Refer yourself to the operator’s guide for additional information.
Tools required:
Front Shocks
Range of Adjustment: *
Factory Setting: 64.1mm (2.52in)
Dune Setting: 64.1mm (2.52in)
Rear Shocks:
Factory Setting: 59.1mm (2.33in)
Dune Setting: 59.1mm (2.33in)
* Do not increase the front/rear spring preload by more than 15 mm (0.59 in.) from the factory setting and do not decrease the front/rear spring preload by more than 5 mm (0.2 in.) from the factory setting.
Measurement and Settings:
2. Spring Crossover:
Your vehicle is equipped with a dual stage spring design. During the initial part of the shock stroke, a softer spring rate provides a comfortable ride. When the shocks are compressed further, a second, stiffer spring rate engages to protect against bottom out and body roll. The spring crossover adjustment allows you to modify when the spring transitions between
the initial (softer) and final (stiffer) rate.
To increase stiffness, turn the crossover rings downward. To decrease stiffness, turn the crossover rings upward.
Tools required:
Rear Shocks:
Factory Setting: 47.9 mm ± 1.21 mm (1.89 in. ± .05 in.)
Dune Setting: 47.9 mm ± 1.21 mm (1.89 in. ± .05 in.)
* Do not increase or decrease the spring crossover by more than 15 mm (0.59 in.) from the factory setting.
3. Low-Speed Compression (LSC):
The LSC primarily affects the compression damping during slow suspension movements such as G-outs or smooth jump landings. It also affects the vehicle’s ride comfort and wheel traction. Choose a LSC setting that gives good body control (roll in corners, dive under braking, squat under acceleration, etc.) without causing excessive harshness or loss of traction.
For more damping (stiffer), turn the screw clockwise. For less damping (softer), turn the screw counterclockwise.
Tool required:
Front Shocks
Range of Adjustment: 4 turns
Factory Setting: 2 turns out
Dune Setting: 1/2 turn out**
Rear Shocks:
Dune Setting: 1/3 turn out**
** To adjust the LSC, HSC and rebound damping, turn adjuster clockwise until it stops, then turn adjuster counterclockwise by the specified amount.
4. High-Speed Compression (HSC):
The HSC adjuster affects the compression damping during medium-to-fast suspension movements such as steep jump faces, harsh flat landings and aggressive whoops. The goal is to run as little high-speed compression damping as possible without bottoming. The HSC gives the ability to externally adjust the damping easily.
For more damping (stiffer), turn the socket clockwise. For less damping (softer), turn the socket counterclockwise.
Tool required:
Front Shocks
Rear Shocks:
Dune Setting: 2/3 turn out**
5. Rebound Damping:
The rebound adjuster affects how the vehicle rolls / pitches under acceleration and braking and also impacts how quickly the wheels return after the shocks have been compressed through a series of bumps. A rule of thumb is that rebound should be as fast as possible without negatively affecting chassis control or feeling bouncy. Excessive rebound damping will typically be felt as suspension “packing”. For high-speed, open desert terrain, you may prefer to run less rebound damping for maximum traction.
For slower rebound, turn the screw clockwise. For faster rebound, turn the screw counterclockwise.
Tool required :
Front Shocks
Dune Setting: 1 turn out**
Rear Shocks:
The left and right shock adjustment on front or rear suspension must always be set to the same position. Front and rear adjustments are interrelated, it may be necessary to readjust the rear shock absorbers after adjusting front shock absorbers. Modify each adjustment one at a time (for example, spring preload adjustment on the four shocks), than test drive the vehicle. Proceed meticulously and methodically until the desired comportment is achieved. Never adjust one shock only, uneven adjustment can cause poor handling and loss of stability. ©2015 Bombardier Recreational Products Inc (BRP). All rights reserved. TM, ® and the BRP logo are trademarks of Bombardier Recreational Products Inc. or its affiliates. In the U.S.A., the products are distributed by BRP US Inc.† All other trademarks are the property of their respective owners. Read the side-by-side vehicle (SSV) Operator’s Guide and watch the Safety DVD before driving. For your safety: wear a helmet, eye protection and other protective gear. Fasten lateral net and seat belt at all times. Always remember that riding and alcohol/ drugs don’t mix. SSV is for off-road use only. Never ride on paved surfaces or public roads. Operator must be at least 16 years old. Passenger must be at least 12 years old and able to hold handgrips and plant feet while seated against the backrest. Never engage in stunt driving and avoid excessive speed. Drive responsibly.
