My Outty in a truck bed?
2 reading
20K views 53 replies 18 participants last post by  sholtz21
Hi all!
Part 1:
Question for you guys, we recently moved and with that, I've lost convenient access to my trailer. I'm looking into getting a truck for other reasons as well, but one thought was to use it to transport the Outty as well. Everything I've read so far says that my 500 XT will fit in a long box with no issue. I've seen posts where people have put a 500cc in a short box, (like 6.5 foot), but it sits on the tailgate. Not sure I'm comfortable with that, I was hoping to avoid a long box, just for the size of the truck though.
I've also read where guys have built a frame/platform for the smaller box, so that the Outty can sit on that, which extends to the tailgate.
Part 2:
For those that live in the Midwest or ice fish, how to transport your house and the Outty? With the trailer it was easy, but now, i've been thinking.... I have an Otter XT Lodge. Once the truck is all figured out, I was thinking of either a raised platform to get the Outty on top, then slide the house in under it... or, getting a hitch mounted cargo carrier and strap the house to that.
If you have pics or anything for an idea please do share.
Thanks!
Shaun
#5 · (Edited)
a short box is normally a 5.5' bed on a crew cab. With that the rear tires on the tailgate it will fit.
with a 6.5' bed (normal bed) it will fit, but the rear tires will be in the crack between the bed and the tailgate.
On a long bed (8' bed) truck you can fit the quad, and close the tailgate. I would invest in tailgate supports.
Reactions: BombardierBomb
Awesome! Thank you all for the input. This is very helpful! I'm I was thinking of the 6.5' bed would work, and this just hopefully confirms it. I'll obviously do some fitment checking when i actually start looking, but this gives me a good idea.
i forgot to add my explanations we based on a MAX length outlander. The 5.5' foot and 6.5' are based off real world experience with my 18 Max XT in the back of a crew cab short bed F150 and my current rig a 12 crew cab regular bed 2500 cummins.
#11 ·
One thing that I would highly recommend all you guys that haul your rides in the back of your truck is to get a set of the DG Tailgate Supports for loading and unloading and if your tires rest on the tailgate, I left mine on during transit. The small tailgate cables have been known to fail and you don't want to deal with that.
#13 ·
Just for comparison/conversation sake:
I've got no qualms about where Kusa's bike is sitting, there's not enough weight on the tailgate to really stress the cables, imo.
On the other hand- Jobo- jeeezus lol, PLEASE support that tailgate before rolling like that again
Reactions: Kusa
#21 ·
Your right, that doesn't sound much, but I think in the truck bed, it's huge!
Mine fits in a short bed but it's sketchy backing down. I since purchased an enclosed trailer. When backing down you can't see the ramps. If you notice in my pic I also place ratchet straps on the tailgate. I don't trust the cables on the tailgate. I also built boxes similar to the pic above so I don't take out my back window. Lastly, as you can see in the pic, I have two 2 X 10's running the full length of the bed to better distribute the weight of the machine across the bed and away from the tailgate. View attachment 100679
After reading everybody's posts, I was thinking of doing something similar with the boards, or almost making a box for it to sit on, so I can slide the house under it. Just depends on deep i can go.
I have access to an enclosed trailer, but I can't store it at my house and it's a pain to have to go get it every time.
#18 ·
100679
#19 ·
Just a FYI, there are companies that make these metal brackets or rods that go on your tailgate when open like how your pic is showing that takes the load off of your cables. Here is one example.
#29 ·
Just came across these as well. a little spendy, but get the bike up in the truck and and strap the ice house to the back of the ramps.
https://madramps.com/product/mad-ramp/
if you are looking for ramps.. check out these ramps. I got them 2 years ago and used them a handful of times. The straps they send with it are useless because they are not long enough. So have your own ratchet straps to secure them. They fold up nicely so you care store them in your cab when you are not around your truck. keeps them from getting stolen!
I have loaded my quad in the bed of my F150 a handful of times, and once into the bed of my 2500 cummins. It gets easier/faster the more you do it. However whenever i do it, i make sure both ramps are 100% lined up. I will place them on the tailgate and strap them into place, but not tight. Ride my quad up to the base of the ramps, but not on them, and make sure my front tires are exactly in the middle of the ramps. Once i have that lined up correctly, i will then strap down the ramps so they don't move. Then i will drive my quad onto the ramps, but only have the front tires on them until the back tires are at the base.
I hop off again, double checking to make sure i'm still straight. If everything is fine, i back up a little bit, and then go all the way into the bed of the truck.
When unloading, i actually remove the 'princess seat' on the back, and even the cargo box i have on the back. This helps a little to see the rear tires. then i repeat the process of loading, but obviously for unloading the quad lol. I always secure the straps to safety chain loops on my receiver and i make sure the straps are good and snug before i put any weight on them.
A trailer is much easier because there is WAY less involved, however you can get to your destination faster if the quad is in the bed of the truck, versus a trailer. Plus you don't have to worry about backing up a trailer, finding enough parking for your rig and trailer, or having a tire trailer pop on you.
I've hauled the quad both ways.. trailer and in the bed of my truck. I prefer trailer, but i don't mind ramps
#27 ·
Same here. I have several trailers and they certainly have their purpose but not for hauling my bike around. I had a trailer get out of control once and it’s no fun.
In my truck, I can’t hardly tell that it’s back there while driving. Only difference is the rear view mirror can’t see through the bike.
As far as not being able to see the ramps while backing up, if you line them up correctly and back out straight, it’s easy peasy lemon squeezey.
I will say that I did order the tailgate braces last night though. That is a great idea. Kudos to the poster that pointed that one out.
#32 ·
this! Mine are like 7' long when opened and even have an arch to them.
#33 ·
I know I would prefer using the trailer as well, but it's just not as convenient now that we've moved. As far as ramps go, I'll get those longer ramps, would definitely make loading and unloading easier! Thanks again for all the advice!
#34 ·
Even though I now use a trailer, when I purchased my ramps for the truck someone recommended making sure the ramps have an arch to them and are not straight. I purchased a set of arched ramps from Cabela's and couldn't have been happier with them.
#46 ·
Time for a lift kit! :p
Reactions: Kusa
