1 - 4 of 4 Posts
Need some help. I installed snorkels on my renegade 1000 2012. I've been riding in lot of water and it has been getting in somehow and making the belt slip. On full throttle, can't even get passed 40mph. Any suggestions in how to troubleshoot?
Take belt housing off and clean the belt, clutches, etc and most likely replace the belt as you have been smoking it.
Are you running some big heavy tires too?
Is it possible the water is getting in through the snorkel? I go pretty fast through large puddles etc, maybe the water is going I through the snorkel?
Did you seal the inner belt cover against the motor? Unless your snorkels werent put together well then they shouldnt be leaking.
1 - 4 of 4 Posts
