No spark when trying to start engine
16K views 10 replies 5 participants last post by  MontanaCanAm
So, I am diagnosing my 2020 Outty 1000r with BUDS2. On the screen I can tell it to activate ignition coils. I select rear coil with spark plug out of the engine and hit activate. It sparks. I crank over the engine and no spark..
I am thinking crank position sensor.
I do have one on order and should have it in 5 to 6 days from now.
Does the BUDS package you bought have a flow chart to tell you which conditions are needed for the coils to activate? Maybe the crank position is one of many other conditions that must be met before they activate.
Reactions: BombardierBomb
BUDS does have hints. But the service manuals do have all the specifics.
Reactions: xsever
By the way, here is an excellent way to load a machine that does not want to start. View attachment 106389
They almost had to unload my ATV at the dealer with fork truck. Only 29 hours on ATV and the starter is done. It started up and I was able to drive off. It is still under warranty so I was having them look at shifter and put on Hand and Thumb warmer plus Track Module. They had no trouble at first with starter move it into shop and did work, mechanic went to move it out of work station and were going to phone me to come get it. But lucky for me it would not start and just click like it did on me. So new starter thanks to BRP and was only charge $110.00 for the labor for other work. Not bad I think. If anybody know these ATVs taking the starter out is not a nice easy job, whole left side comes off to get to the starter. Just want to add too, the Track Module did not take away my speed limiters.
#9 ·
Starts every time like it is supposed to.
Congratulations! Well diagnosed!
Are you going to inform your dealership? Maybe they will cover the cost of the part at least since they weren't even able to diagnose that and fix it?
