1 - 2 of 2 Posts
Does anyone know if older Apache 360 tracks will kit on a 2021 Outlander 1000? I am looking at picking up a used set from 2010 - they were mounted on a 2010 Renegade. Will they mount correctly on the 2021? and if so which mounting kit is required? any help would be great! cheers
Hey, I can't promise but I'm 99% sure the apache 360 tracks use the same mounts as the newer LT ones. As long as they're not the older (non 360 ones, maybe post a picture and I can identify them for you) then you should be fine with the newer mounting kits.
1 - 2 of 2 Posts
