1 - 9 of 9 Posts
So does anyone know how to remove the top speed limiter on 570 max pro 2017?
Why would you? When stock my 570 would go 70mph and that was sketchy. Rarely go that fast.
Jorge- did the "overseas" bikes get a lower speed limiter, tho? I seem to recall reading/seeing something about that...... I'm guessing the OP is able to take his quad out on the roads, and it's probably limited to a lower speed than we're accustomed to.
Regardless, that's a task for someone with the BUDS software, right?
Mine goes only 38mph (60kmh) thats why.
You couldn't even outrun a grizzly bear with that! That's horrible! I don't like the 65mph limiter on mine either. I can get to 65 in a couple seconds then cuts right out.
I had similar issue but after installing 2 new plugs it tops out over 73 mph that's when I let off throttle
Outlander MAX PRO 570 2019
Yes,thats right.
Two different types of registration,one with 40km/h key and another with 60 km/h.
Dealer can "unlock" if they want.
Speedohealer option?
1 - 9 of 9 Posts
