1 - 2 of 2 Posts
Is it better to run solid or stock rubber engine mounts. The other when riding through some mud I notice my engine was flexing/twisting a lot. I was wondering would the solid motor mounts from MrRpm would fix this problem? Or would it be better to stay with the stock ones? Is there any Pros or Cons running the solid vrs the stock rubber mounts?
Better to run solid mounts, all positive to run the solid mounts, there is only a slight increase in vibration but worth it knowing the drivetrain binding won't happen anymore. Also lays power down more efficiently.
1 - 2 of 2 Posts
