1 - 4 of 4 Posts
I have an outlander 850 with a check engine light. I have had no loss of power but i still want to fix the code. When I pulled the code I got the code "U3FFF" and under that it said "FAULT 1" this seems diffrent than other codes so does anybody know what this means?
Regular Joe
2014 Maverick 1000r
Never seen that before :unsure: 🤷‍♂️ google apparently points to a communication issue between the scanner/obd2 device, and machine. Are you doing the headlight toggle to display codes on the cluster?
Yep, its a little confusing that I wouldnt get an actual code.
1 - 4 of 4 Posts
