Outlander max xt 850 fuel economy?
12K views 7 replies 6 participants last post by  zrock
Was interested in seeing what kind of numbers folks have been getting off their machines? I am running 91 octane non ethanol fuel and plan to only run this fuel. If anyone has any experience and numbers, would be great
I can tell you it's all in how you drive it, where you drive it and how heavy thumbed you are. My 650 easily used to get 200-225 miles to a tankful, I upgraded to a big bore 850 kit, mild cam upgrade, maverick heads, throttle body, pipe etc, and even with a **** secondary helix allowing a lot of belt slip and excessive rpm at prime cruising speeds I am still getting over 150 a tank. New helix is enroute so, we will see how much better it gets lol.
One ride that shocked me was we had a 100 miles of trail riding thru gnarly terrain one night, I was in low range for most of it, until it was time to head home, I switched to high after we hit the easy trails/dirt roads to head home and just dropped to 3/8s of a tank on pulling into the driveway. I was stunned, seemed like low range allowed for typical better mileage in rough stuff (like 25mph and under trails) than high range did, because the throttle inputs were so small.
Not sure about the smaller can am's but on my old cat I could get about 225 miles per tank... the new 850 I will be pushing to get 150 and that's with it filled to the top of the neck
