1 - 6 of 6 Posts
Does anyone else have the problem with the rear rack rattling? I've tried tightening all of the bolts but the rattle is still there.. Any help would be greatly appreciated as its getting really annoying.
Might have to add some washers, if I remember there are 6 torx screws and nuts that hold down the rack to the aluminum bars and the two bolts that actually hold it to the frame. If you can't move it then it's got to be something else
I have to tighten the bolts that hold the plastic to the support about every 500 miles or so.
Some of the bolts underneath the rack are hard to get at. I removed the rack then removed all the bolts and add thread locker and re-installed.
Separate the plastic on the rack from the mount. The screws you see on the racks only tighten them to the mount. Your mount is loose. So is mine.
Discussion Starter #6
Yea the mount bolts was loose,man those was a bear to get too! I enjoy the ride ALOT better now...
1 - 6 of 6 Posts
