1 - 5 of 5 Posts
Hi guys I’m having an issue when I install the dynojet power commander 5 with fuel injection. And that is it’s idling high. I pinned it back to the tps plugs as if I disconnect the plugs going into the tps and reattach the stock plugs into tps it’s all good. Now dynojet is telling me that it’s nothing to do with there equipment. Anyone else have this issue?? To me it seems like it’s an issue with the tuner as like I said all the other plugs for the tuner are still attached except the two for the tps
I didish. I say this bc it threw a flashing check engine light and went into limp mode after 15 mins.
Did you reset your tps by any chance? Your can do it through your Power commander software.
I didn’t as the guy from dynojet jet said that should be the cause unless the tps was off to begin with.
1 - 5 of 5 Posts
