1 - 5 of 5 Posts
I just picked up an outlander 850 dps, 2020. I plan to upgrade the shocks as soon as I can get an answer To this question. I see two different part numbers for fox podium x RC2 HPG shocks. One for 2018 and prior G2 models and another for 2019-2020 G2 models. Does anyone know what the difference in shocks is, between the two? I assume one must be longer or shorter to accommodate for the arched a-arm design on newer models? I can get BRP labeled fox podium x rc2 for 2020 model, no issue. I wanted to order directly from fox distributor, so I can get the Kashima coating option and fox factory support, but there is no part # for anything after 2018 from Fox distributor. Are the shocks all the same? Or different Length? Spring Rate? Damping? Anyone know? Thanks in advance! Alex.
Yes arched vs non arched.
Could be many changes. Length, springs, Internal.valving. Only a sho k builder would know
I know, I am hoping someone on here is maybe a technicIan, or someone has one of each parked in garage and could take a look..
Well I will tell you this, 2019 you buy the Fox Podiums for about $714.00. Now the same shock will cost you $1500.00. No difference at all, only that BRP has started to put them on all the XMR models. I know this because my Fox Podiums are wore out and I look into replacing them.
2020 Outlander DPS 850, 2016 Outlander Max XT 1000R
The rear trailing arms are different between 2016 and 2020. I think the rear shocks as a whole are slightly longer now. Maybe an inch or so.
1 - 5 of 5 Posts
