1 - 5 of 5 Posts
Regular Joe
2014 Maverick 1000r
Sounds like a simple failure of the relay, just replace it with a new one.
To confirm, those other 3 in there are identical, simply swap a couple around, buzzing should follow the bad relay.
Hola Buenos dias vieras que pienso que los relevos estan buenos. Luego en la pantalla me apareció un problema de comunicación de transmisión. Le di neutro y luego parqueo. Apreté freno de pie y luego star y editó arrancó y no volvió a sonar el relay dejó imágenes por si a alguien le funciona o tiene el mismo problema.
Según me dice el mecánico es problema del sensor de cambios o velocidad de limpiar o comprar nuevo.
PD: ¿Qué piensan?
Vehicle registration plate Automotive lighting Motor vehicle Hood Automotive tire
Vehicle registration plate Vehicle Automotive lighting Automotive tire Motor vehicle
Hood Automotive lighting Automotive tire Motor vehicle Bumper
Regular Joe
2014 Maverick 1000r
Hello Good morning you see that I think the relays are good. Then a transmission communication problem appeared on the screen. I gave it neutral and then I park. I pressed the foot brake and then started and edited it started and the relay did not sound again, I left images in case someone else has the same problem or it works.
According to what the mechanic tells me, it is a problem with the gear or speed sensor to clean or buy a new one.
PS: What do you think?
I'm in agreement ^
1 - 5 of 5 Posts
