I have a 2003 Quest 500 that I started having issues with this winter. I am getting oil blow by near my plug recess. It stopped running a month ago so I pulled the coil and had oil pooled in the recess where the plug is, I cleaned the oil, removed the plug, replaced the plug and coil (both new). It ran fine then,
problem started all over again. Oil on engine, oil in the recess, etc. It still runs fine, but at this point, I do not know what to do next. Is this problem fixable? did it happen due to wrong oil used? I thought I installed the oil as recommended by BRP. HELP?
Unit has 500 hours and has only ben used to plow snow and haul firewood around the house.
