1 - 7 of 7 Posts
Hello, so have to clean the VSS or speed sensor and i am having trouble getting it out of there...
Is it even possible or do i have to remove the black thing that is blocking it?
I did get the screw out but it just hits the black thing when i try to pull it out.
Automotive fuel system Motor vehicle Automotive tire Hood Automotive design
Automotive tire Coil Motor vehicle Vehicle Engineering
That's just your 4wd actuator, you can remove it out of the way without any special procedure or fuss
Reactions: Tozguy
Nice! Will i have to drain the gearbox oil or not?
It seems to be below the fill plug
Yes if you remove the actuator, gearbox oil will drip down.
Yeah that's what i figured but i just jacked up the RH side of the quad a bit and that worked great, not a single drop of oil
Awesome. That was my lesson learned when I removed the 4WD actuator to inspect it and clean it up.
1 - 7 of 7 Posts
