1 - 4 of 4 Posts
My friend has a rancher 420 4x2, rim size is 24x10x11 rear, and I want to give him my 26x12x12 Mud Bugs. What size rim do I need to fit that tire on the rear. I know the bolt pattern is 110 but I'm not sure on rim size? I know its a 12" but not sure width
He has a Recon 250, rim size is 22x10x9 rear, same thing, but I want to put 26x10x12s MBs on the rear of it. Size? Thank you, Travis
Best thing to do for a rancher is to get some foreman take-off wheels( stock wheels for a foreman will fit a rancher). The rancher has the 12 inch fronts and the 11" rear diameter wheels i think.
Friend of mine was in the same situation, same bikes( rancher and Recon).
I don't know what's the maximum size a recon can use. I know most hondas use the same bolt pattern. It's the wheel backspacing that'll get you into trouble if not careful. And the clearance with the plastics.
1 - 4 of 4 Posts
