I ripped a boot yesterday, and have pulled the axle and I cut off the bad boot off for ease of working, and I am going to pick up a new boot kit in a little bit. My question is on removing the cv joint. The bad boot was on the out side (rear axle) and when looking at the service manual it looks like you should be able to remove that cv joint "put in vice and align shaft with joint and pull" but that don't see to work. (I even put a couple pry bars and put quit a bit of pressure and nothing). Help!!!:th_smiliepullhair:
