1 - 1 of 1 Posts
I have a john deere 650 trailbuck i use to get around my property due to arthritis. I started having a problem with it running real rough,i changed the sparkplug first cause it was so black i figured it was fouled up? Then i took carb off to see if it needed cleaned and found one of the jets had been stripped from last place i took it to. I put a different carb on and still have same issue,it runs just not smooth. I pulled plug again out of curiosity and it was black already, unhooked fuel line and cranked it over to make sure fuel was coming out and it looked ok.. If i give it alot of throttle it seems to feather out and run alittle better, it is just hard for me to work on shit and was hoping for some advice on where else to check for possible causes? I would be very thankful for some help and ideas ,my disability does not allow me to afford to take somewhere. Thanks again
1 - 1 of 1 Posts
