1 - 3 of 3 Posts
I've got myself a 2014 outlander 1000xt mid last summer and am going to snorkel it in a week or two
I also have an 08 outty 800xt that I snorkeled and it works well but when doing so I fount the belt housing to the motor did not seal very well and I had to remove the primary to pull the back off and seal it tight. Now works very well.
Just curious if these newer can ams have anything that I sould really check. I can always test the kit after install but would probably be way easier before the snorkel is installed
Just vents, on your 14 they should already all be ran up under the pos but worth a check, dielectric grease on every electrical connector you can find, silicone the air box cover as it has a crappy seal, test the snorkels before hitting the water, hold hand over air intake and motor should stall out, for ctv snorkels best way to test them is fill em both right up with water and check for leaks, just drain and dry afterwards and good to go
1 - 3 of 3 Posts
