1 - 11 of 11 Posts
Hi all, wasn’t sure where to post this..
I have a 2020 570 outlander max xt, just under 300 miles and 48 hours. Been loving this machine, but recently it has gotten very “squeaky” over bumps. It seems to be suspension, not steering. Last outing I did drive through some water. I greased it an extra time (14 points) and spray lubed the outside of all visible suspension parts, to no avail… any advice?
2020 Outlander DPS 850, 2016 Outlander Max XT 1000R
You can try spraying the top and bottom of the springs in the shocks and working them back and forth with the spring tension adjustment tool. Or lubing the shock attachment points requiring you pull each bolt top and bottom.
Well I sprayed that all and bounced it and sprayed it again, it made approximately no difference. I also regreased the crap out of it… same
Well I would say you need to think about changing your bushings to Garage Product. You will love the difference. My 2014 was the same and Garage Product Bushing Kit was well worth it.
Discussion Starter · #5 · (Edited)
oh I see. Seems kinda wrong to have to spend hundreds of dollars (and the work) on a one year old machine, doesn’t it?
2017 Can-Am Outlander 570 Pro
shock mounts spray with WD 40 once in a while or grease them
I would take the advice and just do the upgrade. You won’t regret it.
This is what the inside of the oem d bushingslook like with 850km and greased every second ride.
Wood Gas Auto part Personal protective equipment Metal
Automotive tire Wood Artifact Rectangle Gas
Automotive tire Wood Artifact Automotive wheel system Gas
This is a good example of what the link bushings look like; all kinds of goodness gets in there and the grease doesn’t get to where it needs to in whatever can am calls this oem disappointment …
Tire Automotive tire Wood Tread Synthetic rubber
1 - 11 of 11 Posts
