Why is the shifter stiff. Its takes a little bit of force to shift gears. Some times ill go into low and its like it gets cought in between high n low, start moving with no problem but when off throttle itll make a grinding noise when coasting.
When i shift from reverse to a drive gear or the other way around it feels like its stuck in that gear n ill pull on the shifter then it will les loose n go into the other gear. Whats the cause of this. Done it since 0 miles. Bike has 160 on it
