Hi
I have found this uni nu-8703st review link
any thoughts on this filter?
www.ATVPT.com - UNI_Filter_NU_8703ST
Donna
Facts:
Uni Filters are a two in one filter.
This means you can take it apart to clean and oil it.
Note: You need to use filter oil on both layers to obtain maximum results.
Uni's are a direct factory replacement.
This means they will fit any stock airbox application without any modification.
Installation is so easy with the Can-Am Renegade, and also the Outlanders too. I have found the Can-Am ATV line to be the easiest ATV to remove the plastic from for maintenance. Installing the air filter is a breeze. Just remove the top plastic, remove the air box lid, remove the air filter, and replace it with the Uni.
I found it easier to remove the 45 degree snorkel with the air filter attached, remove the air filter from the snorkel. You then attach the filter to the snorkel, and install the air filter/snorkel in the air box together as shown in the picture above.
Replace your air box lid, plastic, and you are ready to hit the nastiest of trails.
