1 - 3 of 3 Posts
Was wondering if anyone has installed the bigger a-arms by super atv? Did it improve the ride height? Easy to install? Just general info and all that good stuff.
Thanks everyone
Their description sounds pretty good. I have not bought or used them myself :smilietwocents:
"The Max Clearance Front Lower Control Arms feature a dual bend design giving you the MOST clearance you can get from the frame to the hub without adding a lift. Our a-arms provide almost 2” of additional clearance where you need it the most. We designed the Control Arm Kit specifically for Outlander and Renegade owners who are concerned about the additional wear and tear on a UTV when adding a standard lift kit. By maintain factory drivelines and positions, there’s no added wear and tear on your ATV's components – including the CV axle joints.
The a-arms are crafted from 1 1/16” x .120 wall steel DOM tubing – a serious upgrade from factory materials. Each a-arm features an additional gusset adding even more strength where you need it most. Additionally, the a-arms can reuse your factory ball joints and bushings."
1 - 3 of 3 Posts
